I'm trying out the finite dome with HDRI for the first time today and ran into an issue with a black band between the dome and ocean water. It appears to be the dome casting a shadow onto the infinite ocean and not sure how to get rid of this band.
HDRI Finite Dome Light with Phoenix Ocean
I think that's just the VRayDome's current limit. If you increase its radius, it should go farther away. Otherwise, I presume you're confused as to why the dome's flat part ends before converging to its hemisphere part - although "Finite" is active, the VRayDome is always behind everything in the scene.
- Likes 1
