Passes render shadow catcher plane black
  • Passes render shadow catcher plane black
    I'm currently experiencing the same issue as mentioned here:
    https://forums.chaos.com/forum/v-ray...-of-the-shadow
    except that it occurs in 3Ds Max and the latest V-Ray version.
    When adding the BackToBeauty pass, it'll render the shadow catcher plane black even in the RGB channel. When adding just the Specular and Reflection passes, it'll render the RGB fine, but the passes itself will render the plane black in the reflection again. Reflection pass is completely black. The scene is entirely new and has been tested on several new scenes and the issue persists. Is there any fix or workaround for this? I attached some screenshots
ID:	1214540Click image for larger version
ID:	1214541Click image for larger version
    Hi, thanks for posting. The issue is logged in our bug tracking system under VMAYA-12997. It is a bug that happens in 3ds Max as well. The issue is not fixed so far. I will try to figure out a workaround if possible and get back to you.
    Vladimir Krastev | chaos.com
