Save Cryptomattes separately
  • Save Cryptomattes separately
    could it be that this function doesn't work when used in convination with Deadline software?
    In local seems to work fine but in Deadline I get nothing exported on the cryptomatte side.
    Does anyone knows a fix for this?
    Hi, thanks for posting. Do you want to use the separate channels output for your renders? The Cryptomatte works with multichannel exr and vrimg.
    Vladimir Krastev | chaos.com
      no, not exactly.
      Recently you guys added the ability to just split the cryptomate in the save options.
      That didn't work in deadline because Deadline renders localy the file and then copy that file to the right output.
      But deadline doesn't recognise the new cryptomatte pass, and just ignores it.
      So I guess is not VrayFault, is just deadline doing something wrong.
      The workaround for that is that deadline saves the file directly on the output direction ( network in my case ). that way doesn't need to move files around and the cryptomatte element apears just fine.
