export vrscene - animated camera parameters are not taken into account
  • export vrscene - animated camera parameters are not taken into account
    Hello,
    vrscene export does not take into account changes in the animated exposure value and color temperature of the VrayCamera.
    animation with only a few frames, every frame in an different room of a building, camera exposure and color temperature changes frame by frame. The animation renders with parameters taken from the first frame of the saved range, do not updates in the next frame.
    Tested with 6.20.06 and todays nightly.
    Click image for larger version  Name:	Camera parameters.png Views:	0 Size:	10.6 KB ID:	1215912
    ​Kind regards
    algato
    We already have this issue logged (internal bug-tracker id: VMAX-13772). I'll notify the project manager so as to increase its priority. A workaround may be to use incremental export of ,vrscenes. Basically - a .vrscene for each frame, which will later be combined.
      Hello Aleksandar,
      very interesting, thank you for the hint
