LightMix not working
  • LightMix not working
    I am having an issue with LightMix not working in my frame buffer. It is strange because it has worked before, and even currently works on other scenes.
    From the documents of the process:
    2. Add the LightMix Render Element directly from the VFB. [fine without issues]
    - In the VFB > Layers, set the Source to LightMix. [fine without issues]
    - Click Add LightMix to the scene. [fine without issues]
    - Start a new render to apply the changes. [here is where the problem occurs. When I re-render, the source switches back to RGB. When I click LightMix as the source, the render turns black again.
    - Now you can tweak your lights!
    Does anyone know what could be happening?​
    Timothy Saunders
    Hi, thanks for posting.
    If everything works with other scenes there must be something in the scene that is causing the issue. Could you archive it and send it for review?
    Vladimir Krastev | chaos.com
