"I’m using a referenced object in 3ds Max, and I’ve applied an external reference material to it. I modified the override material in the reference, and when I previewed it using V-Ray IPR, it showed the updated material. However, during the final render, the override material didn’t apply, and it used the original external reference material instead. What could be causing this issue, and how can I properly use the override function with external reference materials?"
Override Function for External Reference Material Not Working Properly
This topic has been answered.
Answer selected by hermit.crab at 19-09-2024, 12:52 AM.
Thanks for clarifying. It turns out we already have this issue logged (internal bug-tracker id: VMAX-8420). The current workaround is to render via Standalone (Main toolbar > V-Ray > .vrscene exporter > Export and Render) instead. Otherwise, I'll mention this to the project manager.Last edited by hermit.crab; 19-09-2024, 12:50 AM.
- Selected Answer
- Selected Answer
Originally posted by hermit.crab View PostThanks for clarifying. It turns out we already have this issue logged (internal bug-tracker id: VMAX-8420). The current workaround is to render via Standalone (Main toolbar > V-Ray > .vrscene exporter > Export and Render) instead. Otherwise, I'll mention this to the project manager.
Another workaround may be to export .vrscenes from the reference scenes and use VRayVRMatMtl instead. Basically, analogical to the xRefs, but with .vrscenes.
