"Missing: IPR"
  • "Missing: IPR"
    Hello,
    3ds Max 2024 and current Vray 6 update 2.1.
    What can I do when Viewport IPR is missing?
    Hi, thanks for posting. Are you sure you have selected V-Ray as your render engine?
    Viewport IPR works as expected on my setup (3ds Max 2024 and V-Ray 6.20.06)
    Vladimir Krastev | chaos.com
      I'm having the same problem. Can anyone help? My setup is 3ds max 2024 using vray 7.00.04. I've reinstalled vray and have also tried to do the vray registration menu in the scripting lister, but that doesn't help either. Please advise.
        If you've installed V-Ray to an arbitrary location, there's a note about this here (last row).
          Nobody could solve my issue yet, it's still there... plenty reinstallations until I gave up.
            Try putting the Toggle manually. Otherwise, resetting the 3ds Max preferences usually helps.
