enmesh and multi tex map
  • enmesh and multi tex map
    So, the issue I found is with enmesh and randomizing maps.
    Like you can see in the uploaded image, randomization only works on positive values of the UVW, to the left of the uvw gizmo, randomization will not happen. In this case I can solve it, but in other situations can cause problems, or simply becomes unusable we are better off with an array or railclone object. Click image for larger version
ID:	1221229 Click image for larger version
    You can check this tutorial. Maybe it could help with the preparation.
    https://docs.chaos.com/display/VMAX/...ation+Textures
      If the issue persists send or attach the scene so we can troubleshoot.
