Vray 7 hotfix 1 - Vraydenoise no longer saves normal
  • Vray 7 hotfix 1 - Vraydenoise no longer saves normal
    Hey all,
    So been rendering out some projects and realized with new Vray 7 (running hotfix 1) my outputs no longer save a "bumpnormals" pass out when saving out animations thru vfb. In the past while using Vraydenoiser it was always also spitting out a bumpernormals as part of the outputs, now I see them rendered but it doesn't save.
    I checked all my settings and it looks identical, so something changed on the backend?
    Yes, the automatically generated denoiser channels are not saved anymore when saving to multiple files (they are saved only when writing multi-channel files) by default. You can add the VRayBumpNormals element manually and then it will be saved.
