Scatter Grass pavers
  • Scatter Grass pavers
    I can't get this to work. Seems it would be easy. What am I doing wrong?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I don't use ChaosScatter and I can't really see the rest of your parameters, but afaik I can see that your map is not correct as it is inverted, You'd want to have white where the black squares are. Also you have lines connecting the corners of your squares, which means if you invert the map you'd also scatter grass on those thin lines.
    Or you can use ForestPack: https://www.itoosoft.com/tutorials/c...ving-and-grass
    A.
    www.digitaltwins.be
      Supposing the grass needs to be in the squares, yes, the map should be inverted. You would also need many more instances to "fill it out" (since the distribution mode is Random). You may also experiment with "Position" distribution, which lets you choose a Grid pattern that you could adjust accordingly.
        Yes, I know that the map is inverted. I realized that after I posted. However, I can't get Choas Scatter or Forest Pro to use it correctly. If I get small enough, it will ignore the map. The Forest link you have is when the pavers are geometry.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Uncheck 'per square', set amount until they fill the spaces. Currently you have 30k per 2ft which is ofc excessive and I guess might cause an issue.
          Anyway, this screenshot show what I quickly just did with default everything but what you see, using both Scatter and Forest and that map
            I use the same method with just a regular map + displacement and ForestPack + a mask.
            Is your mask set to use no color transfer function? And is it pure Black/White?
            In Forest Pack just make sure that the resolution of the mask is set high enough in the settings of the FP Object. (My mask is 16K pixels so I matched that in FP)
            This is my preset that I use daily in Forest Pack:
            I tried to recreate it in Chaos Scatter with no issues:
            A.
            www.digitaltwins.be
              Awesome! I tried for hours. I'll take a look at your setup. Thank you.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
