Hi everyone,
I have a problem that I can't seem to solve, so maybe someone here has encountered a similar situation and knows the solution.
Hardware and setup:
Two identical computers:
Problem description:
The test scene contains two sets of Scene States with different lighting.
In Batch Render, I set up two test renders, each with a different Scene State.
I check Net Rendering and Distributed Rendering in the V-Ray options.
I send everything to Backburner.
What happens:
If I run the renders directly in 3ds Max on the workstation, everything works correctly.
When using Backburner:
What I've checked:
Question:
Has anyone encountered this behavior in Backburner? Maybe some configuration is missing, or something needs to be set up differently in Scene States, Batch Render, or Backburner?
Thanks in advance for your help!
Hardware and setup:
- Workstation
- Render node
Software: 3ds Max + V-Ray (Distributed Rendering enabled)
What happens:
- The workstation renders correctly (correct Scene State).
- The render node does not load the Scene State – it seems to use the current layer settings instead of those from the Scene State.
What I've checked:
- The network is configured correctly. When both computers render together without Backburner (within Max), everything works as it should.
Question:
