hello, i am rendering a image sequence with a big resolution. A couple of frames render fine and then one frame show 2 strange lines of dots artifacts and gets stuck on the frame. I have set a time limit of 1.5 minutes , but even if i make it 5 minutes it just has the same artifact and doesn't finish the frame.
Here are some facts about the render
resolution: 8884x2988
progressive render with 1 or 2 minutes time cap
the earth atmosphere is a light material with a composite map with 3 fallofs , 1 of which is light/shadow (gpu doesnt freeze but doesnt support this and cant replicate it with other methods)
no even rendering elements for now
scene is lit by a vray sphere light with 700 multiplier and its not really far from the earth. It is also animated with an upwards direction to imitate a sunrise to lit the planet.
Is there a way to save the project? Problem is it renders for example frames 0,1 and stucks on 2, i tried 3,4 - stucks, i tried from 100, it rendered 5 frames this time and then the artifact.
