Hi there,
We want to use V-ray standalone for batch rendering of .vrscene scenes. We exported scenes from 3ds max using the following command
When we render such scene, we see the following issues:
We see this block of params in .vrscene file but it seems like it is not being used?
We run V-Ray standalone like this
What settings do we need to provide via cmdline to mimic the render output produced by 3ds Max V-Ray GUI/plugin? What parameters do we need to use for standalone tool? We thought the Standalone will read all settings from .vrscene file?
Best wishes,
Petr
Code:
rt.execute(f'vrayExportVRScene "{output_dir}\\{scene_name}.vrscene" exportSetting:true startFrame:{start_frame} endFrame:{end_frame} exportRegion:false')
- Resolution set in Render settings is not respected
- Rendering device type is CPU (VFB shows CPU)
- Output image is noisy, seems like denoising is not done at all?
Code:
SettingsRTEngine rtEngine_settings { gi_depth=3; cpu_bundle_size=128; cpu_samples_per_pixel=4; gpu_bundle_size=192; gpu_samples_per_pixel=16; low_gpu_thread_priority=0; coherent_tracing=0; stereo_mode=0; stereo_eye_distance=6.5; stereo_focus=2; opencl_texsize=512; opencl_resizeTextures=0; opencl_textureFormat=2; progressive_samples_per_pixel=1; undersampling=2; disable_render_elements=0; max_render_time=0.5; max_sample_level=2; noise_threshold=0.1; max_draw_interval=150; min_draw_interval=50; interactive=0; enable_bucket_sampler=0; out_of_core=0; out_of_core_textures=0; }
Code:
vray.exe -sceneFile="scene.vrscene" -imgFile="vray_renders\render.png" -camera="Camera0"
Best wishes,
Petr
