Crash (Memory related?) when rendering .vrscene via V-Ray Standalone (CUDA engine, Windows)
  • Crash (Memory related?) when rendering .vrscene via V-Ray Standalone (CUDA engine, Windows)
    Full error message:
    Error running command: Command '['C:/ProgramData/Autodesk/ApplicationPlugins/VRay3dsMax2025/bin/vray.exe', '-sceneFile="AI47_005.vrscene"', '-imgFile="eval_renders\\render.png"', '-frames=0-12', '-skipExistingFrames=1', '-camera=ProceduralCamera', '-region=none', '-rtEngine=5', '-autoClose=1', '-displaySRGB=0', '-display=0', '-verboseLevel=3']' returned non-zero exit status 3221225477.
    I'm trying to figure out how to debug this random crash. It seems like some kind of memory error? I've set up a camera via maxscript and then exported .max scene into .vrscene format. Then I render such scene using above command and it results in a crash!
    How can I debug this crash?
    This is full log
    Code:
    [2025/Mar/28|14:39:30] [37 MB] Reading configuration from "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax2025\bin\vrayconfig.xml"
    [2025/Mar/28|14:39:30] [70 MB] ===============================================
    [2025/Mar/28|14:39:30] [70 MB] V-Ray Standalone, version 7 Standalone Hotfix 1 for x64
    [2025/Mar/28|14:39:30] [70 MB] Copyright (C) 2000 Chaos Software EOOD. All rights reserved.
    [2025/Mar/28|14:39:30] [70 MB] Use -credits option for additional third-party copyright notices.
    [2025/Mar/28|14:39:30] [70 MB] Build 500f34b3 from Nov 17 2024, 17:57:31
    [2025/Mar/28|14:39:30] [70 MB] Compiled with Microsoft Visual C++ compiler, version 19.4, target ISA: avx2
    [2025/Mar/28|14:39:30] [70 MB] Operating system is Microsoft Windows 11 Pro (Build: 10.0.26100)
    [2025/Mar/28|14:39:30] [70 MB] CPU: AMD, AMD Ryzen 9 5950X 16-Core Processor            , 3400 MHz, threads: 32
    [2025/Mar/28|14:39:30] [70 MB] ISA: SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, POPCNT, SSE4a, AVX, AVX2, FMA, BMI1, BMI2, SHA, F16C, VAES, VPCLMULQDQ
    [2025/Mar/28|14:39:30] [70 MB] RAM: 65456 MiB
    [2025/Mar/28|14:39:30] [70 MB] V-Ray core version is 7.00.04
    [2025/Mar/28|14:39:30] [135 MB] [USD] Loaded 0.23.11 USD provider.
    [2025/Mar/28|14:39:31] [143 MB] Loading plugins from "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax2025\bin\plugins\vray_*.dll"
    [2025/Mar/28|14:39:31] [143 MB] 82 plugin(s) loaded successfully
    [2025/Mar/28|14:39:31] [143 MB] Finished loading plugins.
    [2025/Mar/28|14:39:31] [143 MB] Reading scene file "AI47_005.vrscene"
    [2025/Mar/28|14:39:31] [280 MB] AI47_005.vrscene: done [ 0h  0m  0.1s]
    [2025/Mar/28|14:39:31] [280 MB] File version is 1.00
    [2025/Mar/28|14:39:31] [280 MB] Scene file parsed successfully in 0.1 s.
    [2025/Mar/28|14:39:31] [280 MB] Scene created successfully.
    [2025/Mar/28|14:39:31] [280 MB] Objects in scene: 3315
    [2025/Mar/28|14:39:31] [280 MB] Starting render sequence.
    [2025/Mar/28|14:39:31] [280 MB] Setting number of rendering threads to 32.
    [2025/Mar/28|14:39:31] [280 MB] GI engines: 'Brute force' and 'Light cache'
    [2025/Mar/28|14:39:31] [280 MB] Preparing renderer...
    [2025/Mar/28|14:39:32] [395 MB] Creating bitmap manager
    [2025/Mar/28|14:39:32] [395 MB] Bitmap manager created.
    [2025/Mar/28|14:39:32] [395 MB] Tiled texture cache set to 4000 MB
    [2025/Mar/28|14:39:32] [395 MB] Preparing scene for rendering...: done [ 0h  0m  0.0s]
    [2025/Mar/28|14:39:32] [395 MB] Light tree is enabled with clamp coefficient 0.1 and even split coefficient 0.5.
    [2025/Mar/28|14:39:32] [395 MB] warning: KD tree light cache not supported on GPU, switching to hash map light cache.
    [2025/Mar/28|14:39:32] [395 MB] warning: Light cache is used for glossy rays; it is recommended to turn on light cache retracing.
    [2025/Mar/28|14:39:32] [395 MB] CUDA renderer requested.
    [2025/Mar/28|14:39:32] [395 MB] 1 plugin(s) loaded successfully
    [2025/Mar/28|14:39:32] [395 MB] CUDA renderer plugin successfully loaded from "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax2025\bin\rt_cuda.dll"
    [2025/Mar/28|14:39:32] [395 MB] CUDA renderer plugin instance successfully created.
    [2025/Mar/28|14:39:32] [395 MB] EXT_RTOPENCL interface obtained successfully from CUDA renderer plugin instance.
    [2025/Mar/28|14:39:32] [395 MB] Using normal thread priority.
    [2025/Mar/28|14:39:32] [395 MB] ========================
    [2025/Mar/28|14:39:32] [395 MB] Starting frame 0.
    [2025/Mar/28|14:39:32] [445 MB] Bitmap file "maps\Am158_056_MetalBase.jpg" loaded.
    [2025/Mar/28|14:39:32] [445 MB] Bitmap file "maps\Am158_056_reflect_map.jpg" loaded.
    [2025/Mar/28|14:39:32] [445 MB] Bitmap file "maps\Am158_056_metal.jpg" loaded.
    [2025/Mar/28|14:39:32] [445 MB] Bitmap file "maps\AI47_005_Speaker_Mask.jpg" loaded.
    [2025/Mar/28|14:39:32] [460 MB] Bitmap file "maps\Am158_016_reflect_map.jpg" loaded.
    [2025/Mar/28|14:39:32] [460 MB] Bitmap file "maps\Am158_039_reflect_map.jpg" loaded. [ 0h  0m  1.6s est] [0 MB resman] [0 MB texman]
    [2025/Mar/28|14:39:32] [460 MB] Bitmap file "maps\Am158_004_metal_color_v2.jpg" loaded.
    [2025/Mar/28|14:39:32] [460 MB] Bitmap file "maps\Am158_004_reflect.jpg" loaded.
    [2025/Mar/28|14:39:32] [476 MB] Bitmap file "maps\Am158_036_reflect_map.jpg" loaded.
    [2025/Mar/28|14:39:32] [476 MB] Bitmap file "maps\Am158_036_metal.jpg" loaded.
    libpng warning: iCCP: known incorrect sRGB profile
    [2025/Mar/28|14:39:32] [476 MB] Bitmap file "maps\AM160_021_book_pages.png" loaded.
    [2025/Mar/28|14:39:32] [476 MB] Bitmap file "maps\AI47_005_scratches1.jpg" loaded.
    [2025/Mar/28|14:39:32] [476 MB] Bitmap file "maps\AI47_005_flower_004_color_02.jpg" loaded.
    [2025/Mar/28|14:39:32] [476 MB] Bitmap file "maps\AI47_005_flower_004_color_03.jpg" loaded.
    [2025/Mar/28|14:39:32] [476 MB] Bitmap file "maps\Am158_046_metal_color.jpg" loaded.
    [2025/Mar/28|14:39:32] [476 MB] Bitmap file "maps\Am158_046_reflect.jpg" loaded.
    [2025/Mar/28|14:39:32] [476 MB] Preparing scene for frame...: done [ 0h  0m  0.4s]
    [2025/Mar/28|14:39:32] [542 MB]   Bitmap file "maps\AI47_005_wood_table.jpg" loaded.​
      Could you send the scene so we can troubleshoot it?
        Yes, sure. I've created the request: https://support.chaos.com/hc/en-us/requests/363841
          Thank you. I am reproducing the crash and indeed seems quite random (sometimes it renders the whole range without any issues), however, I don't see the "returned non-zero exit status 3221225477.​" error in the log. Where did you get that from?
            Ok, good to know it is the crash!
            I got that message from executing V-Ray Standalone command via python. That exit code comes from Python subprocess call I think. Please let me know how we can debug this crash
              The devs need to take a look at it because I don't see another way to troubleshoot the crash. I'll notify you whenever I have more info.
