Problem behind glass in GPU mode
  • Problem behind glass in GPU mode
    here's my problem.
    A FloorGenerator floor behind glass. Ok in CPU Mode. Problem in GPU Mode.
    Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.571 + V-Ray 7.00.03
    3DS Max 2024.2.7 + V-Ray 6.20.06
    3DS Max 2025.3 + V-Ray 7.00.04
    Chaos Vantage 2.7.1
    GeForce Studio Ready Driver Version 572.16​
    Hard to say what's going on without the scene. Simplify it and send it via the contact form.
      Scene sent. (Request #362913)
      Chaos Vantage 2.7.1
        Thanks for the provided scene. The darkening seems to be caused by VRayPlane001, which overlaps with the floor geometry. On top of that it has Trace Reflections/Refractions off, which pronounces it. It is visible in CPU too, but milder. I doubt you need this VRayPlane, so I suggest you either delete it or reenable its refl/refr tracing to fix the issue.
          Thank you.
          The VRay plane is the problem.
          Why is it only a problem behind the glass?​
          Chaos Vantage 2.7.1
            Because it had Visible in Reflections/Refractions off, which made the overlap visible.
