Camera
  • Camera
    I have been having an issue with the V-Ray Camera. The only way I can move the camera is by some point in the middle, between the camera and the target. I want to grab the camera and move it. Also, I can't orbit the camera at all.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Sounds like your pivot center is set to selection center, not sure without screenshots but check if it's set correctly: https://help.autodesk.com/view/3DSMA...6-84380E12C8C3
    A.
    www.digitaltwins.be
      Changing the pivot center isn't working for me. I'm having the same issue, with all cameras. I figured it was a new FEATURE after upgrading to 2025 from 2018... thanks Autodesk
      edit: tried several cameras -- standard free camera I can click to select or drag to select, phyiscal camera (with targeted turned off) I can't click to select or drag to select unless its a large selection area (that I guess includes the invisible target?), vraycam I can click on but can't drag to select unless target is included.
      Brendan Coyle | www.brendancoyle.com
        It works for me.
        Be careful to click on the edges of the camera and/or target symbol.
        If you click on the direction line (even inside the symbols), it selects both.
        Otherwise, you can select either the camera or the target using Scene Explorer.​
        Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
        Sketchup PRO 25.0.634 + V-Ray 7.10
        3DS Max 2025.3 + V-Ray 7.00.08
        3DS Max 2026 + V-Ray 7.00.08
        Chaos Vantage 2.8
        GeForce Studio Ready Driver Version 572.16​
          Did you turn on GPU hittest by any chance?
          nitrousgraphicsmanager.HardwareHitTestEnabled=true
          If so that's why, GPU hittest has a problem with selecting cameras, forestpack, railclone, forces, etc. Not with geometry or splines though.
          A.
          www.digitaltwins.be
            that's it - false I can select cameras, true I can select geometry properly
              Yeah I've put it as a shortcut, as having it enabled greatly improves viewport performance for me, and if I need to select something like a camera in the viewport I quickly disable it. It's a bit stupid that they stopped developing the GPU hittesting as the performance is a lot better. Well at least on threadripper CPUs with a somewhat lower clockspeed, havent tried on CPUs with a higher one.
              A.
              www.digitaltwins.be
