more memory issues.
  • more memory issues.
    i am rendering some scenes for an animation where the rendering frequently uses between 2 and 3Gb of RAM. Through monitoring the memory usage I notice VRay does two things...
    1. It doesnt unload the bitmaps loaded for rendering ( I have alot of them, hence it uses alot of RAM) - this makes further work really slow.
    2. It seems unable to clear the RAM back to its pre-rendering state. It seems to accumulate 200-300Mb each time - which means I have to restart MAX eery two or three renders.
    Can this be fixed? Its a real pain on large scenes.
    Thanks
    hi mark,
    you can run a simple maxscript to clear the bitmaps at the end of each render.
    freescenebitmaps()
    Works really well.
    Also are you using max's bitmap pager?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      I am using the bitmap pager.... Im not sure though how much difference its making - do u have lots of experience using it?
        Re: more memory issues.
        This was specifically done to match what the scanline renderer is doing. As jacksc02 pointed out, you can clear the bitmaps manually.
        This may depend on your V-Ray settings. By default, V-Ray does not clear any GI caches at the end of the rendering, unless you specify otherwise.
          apparently everyone has been raving about a plugin called wavgen which is great when using large bitmaps
            It seems like after a while (loading in 10 hires HDRs separately) that this script stops working - at least it stops displaying in the mat editor which is on the other monitor. Is there a separate script to refresh that?
            Also, I am lazy with a bad memory for words - how do i make these into buttons?
            LunarStudio Architectural Renderings
            HDRSource HDR & sIBL Libraries
            Lunarlog - LunarStudio and HDRSource Blog
