Matte problems
  • Matte problems
    Hi Vlado,
    I posted this before, a while ago: I keep noticing that rendering of matte surfaces considerably slows down a render when using the Light Cache. When using Light Cache for both primary and secondary GI, you really notice it. Try the following:
    1: Create a large ground plane.
    2: Give it a standard V-Ray material.
    3: Set the plane's properties to be a matte surface with an alpha contribution of -1 and affect shadows and affect alpha switched on.
    4: Create a direct light with V-Ray shadows on, create some arbitrary objects to cast shadows on the matte plane and put a Gradient Ramp map in the background map slot.
    5: Render the scene using Light Cache for both primary and secondary GI in a fairly large resolution [1600 x 1600 or so] and check the difference when you switch off the matte properties of the ground plane and rerender.
    Speaking of matte problems: when using Delone Triangulation, shadows do not seem to work on alpha surfaces.
    Cheers,
    Metin
    Sevensheaven.nl — design | illustration | visualization | cartoons | animation
