max 8 service pack 1
  • max 8 service pack 1
    Anyone running this yet?
    http://usa.autodesk.com/adsk/servlet...linkID=5573636
    yep, no problems so far. It fixed the refine spline command so im a happy bunny
    mdi-digital.com
      I refused to run max8 cause of the spline bugs and other issues but Ive since installed SP1 and no real issues I can find yet I mite actually put it into the pipeline if all is good over the next couple small projects Im working on.
      -dave
      Cheers,
      -dave
      â–  ASUS ROG STRIX X399-E - 1950X â–  ASUS ROG STRIX X399-E - 2990WX â–  ASUS PRIME X399 - 2990WX â–  GIGABYTE AORUS X399 - 2990WX â–  ASUS Maximus Extreme XI with i9-9900k â–
        I haven´t got any problems with it either.
        My Youtube VFX Channel - http://www.youtube.com/panthon
        Sonata in motion - My first VFX short film made with VRAY. http://vimeo.com/1645673
        Sunset Day - My upcoming VFX short: http://www.vimeo.com/2578420
          I'm crashing more....but can never tell if it's because I'm doing new stuff at the same time or if it's just less stable. Sometimes the fix one thing and ruin 3 other things. Ya never know.
          vray seems to work fine with it though. I've been using it since the day after sp1 came out.
          hmm, I guess maybe that's only been about a week, but still no problems yet.
            I am actually getting VRay errors since installing Max 8 SP1. I have reinstalled VRay with no luck.
            Basically, on launching Max, it says both plugins for VRayFur and VRayPlane failed to initialize.
            I am going to try and uninstall Max, wipe, and install it all again to see if that changes anything.
              Same problem shaneburger and a reinstall fixed the problems. Also watch out that you have your paths correct to the plugins of Vray.
              rpc212
              "DR or Die!"
                it has been mentioned before that those plugins have issues with vray and max 8, i think there is a vray build for max 8 at the download section which could resolve those issues as I dont have any of those messages.
                Dmitry Vinnik
                Silhouette Images Inc.
                ShowReel:
                  one of our computers had the same prob as shaneburger.
                  We have 3. I just copied those from my machine and pasted them onto hers. It fixed the problem without a huge reinstall.
                    Hi!
                    we have weird problems with max8 sp1 Vray1.47.03 (for max
                    and Backburner, let me explain:
                    we are currently doing some animations and rendering through backburner
                    on 4 comp, the max file has all the textures/destination paths specified through
                    the network (full path)
                    the manager comp renders everything normaly
                    the clients do what they want (for example a vray displacement doesn't
                    appears on only one comp, but the rest are normal)
                    and it starts to make me loose lots of time cause I can't spot the problem
                    source.
                    we already did a previous work (it was max7.5 back then) with the
                    same method, and everything worked just fine, fast network render,
                    life was beautiful then
                    now I don't know what is bugging, max8? vray? (please don't shoot)
                    when I render scenes without Vray, it's working fine (for example to save
                    time I render opacity mapped object with the default scanline render and
                    add the pass in After Effects) but when Vray scenes render (mostly the
                    vray displacement) there is problems.
                    yesterday night I did a network render again, when I came at work I saw
                    that after few frames 2 comp crashed (timeout??) I reassign the same
                    job to a comp and it rendered normally (???)
                    I'm really lost...
                    I specified the Vray Displacement file throught the network, still the same
                    problem
                    I'm doomed (I have to finish this project on Thursday, and I have
                    a huge amount of work left to do..) I'll need some serious coffee
                    edit: and I can't say that it is a network problem cause when I'm at work
                    the network is fine..
                      mediadream I never had those kind of problems..have you isntalled backburner 3 patch? that could be something to do with it.
                      Dmitry Vinnik
                      ShowReel:
                        Pardon me, a patch?
                        Ouch.. I didn't installed any patch for backburner that comes with Max8,
                        the only patch I installed was the Max8 Sp1
                        I'll search for this, thank you so much!
                        (I pray for this to be the answer of our problems )
                          my apologies, the backburner patch is still in the beta works, and is not released
                          Dmitry Vinnik
                          ShowReel:
                            I was going to post that I can't find it
                            erRrrR.. I guess I'll have to suffer 'til the end of this project
                            Then the problem might come from Backburner? well, not really easy for
                            you to guess I know, but I'm totally lost, only default scanline renders
                            work fine with Max8 and Backburner 3.
                            I miss Max7.5 already..
                            but I can't understand a simple thing, is Autodesk searching to look like
                            Microsoft? I mean, do they want to release software that only works
                            after you applied several Service Pack? I know it's hard to spot
                            every single bug, but they also try to release new ver to keep competiting
                            other softwares and I hope it'll not turn for us, licensed users, becoming
                            beta testers and having to keep downloading patch/sp to have an healthy
                            workflow
                            I mean, after receving our Max8 I checked the website and saw that
                            a Sp was already needed to correct bugs (it must be tuff for
                            someone with a simple 56k connection)
                            anyway, I don't wana look like someone who complains too much,
                            I hope in a near futur that we'll not need any SP to get our software
                            works fine
                            thanks again for trying to help us
                            • #15
                              somehow they must provide value to the subscribers
                              ever since they adopted that "one major version every 12 months" schedule things have gotten worse
                              cu mike
                              btw: we already had problems with backburner back at max 6 - it really is a shame you have to update backburner with every version of max you install on your machine
                              unfortunately the alternatives (smedge3, deadline, i think there were more) are a bit costly
