Unable to render shadow pass at high res
  • Unable to render shadow pass at high res
    I want to render only the shadow pass of a rendering at high res. When I use the vray frame buffer at 8000x6000, the max frame buffer is also 8000x6000 and I get the 'unable to create bitmap error'. When I uncheck 'get resolution from max', max crashes.
    What else can I do?
    1.47.03
    Thanks,
    Ivan
    all objects in Vray Properties matteshadow, receive shadow on.?
    Jonas
    www.jonas-balzer.de
    www.shack.de
      Try unchecking get resolution from max, and set the res in the common rollout to 0x0 pixels. If it isnt set to 0x0 it will still create the memory buffer for it. Also uncheck "Render Framed window" in the common rollout.
      Then you might wanna try rendering to disc directly (vrimg)
      Thorsten
