viz2007 and DR
  • viz2007 and DR
    hello, i have installed viz2007 on my pcs and try to work with vray DR, but i allways received an error message first in viz viewport:
    "Attention
    file c:\Programas\Autodesk\viz2007\network\vray_client_ scene.max is possibly corrupt"
    would like to try to resave?
    this file i´m testing is just a plane and boxes without any materials.
    than i hit "yes" to resave , the render start and than i get an error message in vray messages "warning : Render host 192..... failed"
    this is only with viz2007 , i have viz 2006 and it works perfectly without any error messages.
    Any idea about this problem?
    regards
    paulo silva
    paulo, had this problem myself...but got it working. Apparently, VIZ 07 doesn't create a directory labeled "network" in the root like it used to, and since vray's DR is looking for it, you get problems. I simply created this directory in my VIZ root directory (i did this on the host and all slaves, btw - not sure if it's necessary), and all should work after that.
    HTH,
    ME
    Talk nerdy to me...
    Matt English
    base2studios
    VizDepot.com moderator
      thank you a lot , i have created the directory "network" and now is ok, .
      One more question if you don´t mind , you have experience problems with textures? not rendering properly , check this tread;
      http://www.chaosgroup.com/forum/phpB...ic.php?t=11640
