Camera correction modifier
  • Camera correction modifier
    Hi
    when i'm using Camera correction modifier for my CAMERA and then rendering i have this WARNING message (in vray MESSAGES WINDOW):
    warning: Camera matrix is not orthonormal and 'Max-compatible ShadeContext' is ON
    warning: Standard materials and lights may shade incorrectly
    warning: 0 error(s), 2 warning(s)
    i can't understand this is real danger message or not ... where is the problem and how to correct render with CAMERA CORRECTION?
    10x in advance
    ARCHITECTURAL VISUALIZATION
    www.projects3d.com
    Hi and welcome to the Forum !
    This warning message tells you exactly what it says, that the matrix is not correct.
    This however can lead to some serios mistakes, like Splotches, not correct shadings etc.
    Solution:
    in the VRay::System menu, check OFF the the
    < MAX Compatible ShadeContext > and it will be OK !
    nikki Candelero
    .:: FREE Your MINDs, LIVE Your IDEAS ::.
      10x
      sometimes my materials looking different in WINDOWS PREVIEW (textures) and after rendering (maybe problem is from camera correction or COLOR MAPPING)?
      www.projects3d.com
        That can be a reason, Yes. Also any type of Gamma enabled can also lead to differences in the ME and the render output.
        nikki Candelero
