Hello,
I've been playing with more glass/caustics stuff. I don't know if there's something with my settings (and if so, I'm not sure which one), but I'm getting this odd phenomena where the mesh lines are visible in the caustics. If I turn caustics off, there are no mesh lines visible.
Look at this first image. In the lower left shadow area where the caustics are present, you can see the fine mesh lines. I added a render-time smoothing of 3 iterations on the mesh.
Now look at the following image, where I've reduced the mesh smoothing from 3 to 2 iterations. Clearly, the mesh lines are changed now - as you can see again in the shadow area. It's fairly simple and straightforward stuff. Is there something wrong with my settings somewhere?
Thanks!
PS: I just used the default VRay caustics settings.
Thanks!
