I'm having a very weird problem with Lightcache crashing when there is an environment map loaded. Everything renders fine with no environment map (background map). There are some other weird things though so I will go through my tests.
I have 3 identical machines, on which the error only happens on two of them (AMD MP2800, 2G ram). I aso do not get the crash on a dual 2.8 Xeon.
The error happens with any file, even new simple "teapot" files.
Yes, all machines can "see" the map.
As stated above, unchecking the "use map" toggle in the environement dialog window allows everything to render fine.
It isn't a memory issue, I've created a tiny 100 pixel map and still get the error... it is spherical.
Error also occurs if I use the relection/refraction/env Vray override.
I've tried several maps to confirm it isn't a corrupt file but some machines can render it anyway.
This is the last few lines of the vray log before it crashes
[2006/May/6|15:50:25] Preparing ray server.
[2006/May/6|15:50:27] Scene bounding box is [4293.54,-1192.37,-512.392]-[10868.6,4893.81,343]
[2006/May/6|15:50:27] Preparing direct light manager.
[2006/May/6|15:50:27] Preparing global light manager.
[2006/May/6|15:50:27] Irradiance sample size is 84 bytes
[2006/May/6|15:50:27] Photon size is 56 bytes.
[2006/May/6|15:50:27] Broadcasting NOTIFY_PRE_RENDERFRAME.
[2006/May/6|15:50:27] beginFrame() done.
[2006/May/6|15:50:27] Broadcasting NOTIFY_BEGIN_RENDERING_ACTUAL_FRAME.
[2006/May/6|15:50:27] Setting up DoneCallback.
[2006/May/6|15:50:27] Rendering frame region (0,0)-(1000,500).
[2006/May/6|15:50:27] Lightmap sample size is 72 bytes.
[2006/May/6|15:50:27] Building light cache.
[2006/May/6|15:50:27] Tracing 250000 image samples for light map in 2 passes.
[2006/May/6|15:50:27] Setting up 2 thread(s)
Any ideas?
EDIT: It also appears that with an environment/background map enabled, these machines can not participate in DR either. Those same nodes fail.
Any ideas?
