Need help with reflection problem
  • Need help with reflection problem
    In the course of work we use low settings for test renderings
    and high for final. I dont recall seeing this before but one of my co-workers ran into it. Now of course there is a difference but I dont quite
    understand why. See below. When using the low settings the hilight/reflection
    looks correct but when using much higher settings it does not.
    We are using camera correction and have tried with and without
    and turning max shade contect on and off.
    and
    thanks
    d
    "It's the rebels sir....They're here..."
    Update: so far this looks like something going on with the just the reflection itself, working on it now.
      well...I doubdt its the reflection. Since the reflection is always right. I see some normals issues on your surface, might want to check that out.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        It looks like if the fresnal is locked it is ok, still comparing 2 materials. hopefully have an update tomorrow
          if you think its a fresnel issue, try placing fall off map into reflection slot with fresnel checked and see if that helps.
          Dmitry Vinnik
          ShowReel:
            Will do, many thanks
              Wouldnt you do that with Fresnel "Unchecked" not "checked"?
