green/yellow render
  • green/yellow render
    hi guys
    has someone ever encountered such wierd render-output?
    mats are all vray (1.47.03).
    thanks.
    ale
    ____________________________
    www.indivizuals.ch
    Weird actually. If you cannot find the problem, can you send me an archive of the scene < nikki@chaosgroup.com >
    Any MAX exposures on ?
    nikki Candelero
    .:: FREE Your MINDs, LIVE Your IDEAS ::.
      It almost looks like a bad authorization it use to do that with some of the older builds but what you see in green would have been red. I would double check your auth code and/or check for raytraced materials.
      -dave
      Cheers,
      -dave
      ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
        at 1st it almost looked like one of the color channels was turned off as well
          check your ram usage... we had similar issues when not all textures fitted into memory - but in fact it's just a shot in the dark as it looks not exactly like the problems we had
          good luck,
          michael
          This signature is only a temporary solution
            thanks guys
            well i don't think it has to do something with the auth (1.47.03 is that already that old?)
            we never use max mats/maps so no raytrace mat in the scene.
            @nikki: i'll send you the file next monday
            cheers and heav a nice week end
            ale[/code]
            www.indivizuals.ch
              hi there
              it seems that we've solved the prob.
              there were some glossy refr. mats. after setting
              back the refr. glossy para to 1.0 everything renders fine.
              the scene was just too big to send nikki.
              regards
              ale
              www.indivizuals.ch
                Good happy to know you fixed it.
                nikki Candelero
