vray-fur is not rendering in the whole image
  • vray-fur is not rendering in the whole image
    hi
    i have a problem with vray-fur (grassarea)...
    rendered irrmap without it and want to render the picture then with it ...
    if i render small regions i have no problem (looks good)...if i render the whole image it renders at a small area then it is away in the next buckets... (rendered on one machine...noDR)
    max6sp1 vray 1-4703 winxpsp2-2gigram
    thanks for any help
    thomes
    I've been having this problem too, the solution for me has been to merge everything into a new scene and then it will render allright for a while until it breaks again then merge into a new clean file...
    Haven't had much time to figure out what is happening.
    Eric Boer
    Dev
      thanks a lot rerender...will give it a try...
      thomes
        It can be a topology problem, so can you show the wire of the grass faces.
        nikki Candelero
        .:: FREE Your MINDs, LIVE Your IDEAS ::.
          hi
          found out that if i dont render one of the three vray-furs (the small one) the other two render okai...
          if someone wants to look at the file...candelero...
          file
          thomes
            I've seen the scene.
            You may need to re-organize (tesselate more) your topology.
            Take a look at this thread by Morbid. It is about displacement, but it
            has 100% same weight, when it comes to furs.
            http://www.chaosgroup.com/forum/phpB...ic.php?t=14300
            nikki Candelero
