shadowing at edge of vray light
  • shadowing at edge of vray light
    in this image you will see some strange banding (hilighted with the red arrows). This is happening at the edge of a large vray light that is floating in the middle of the space and casting light both up and down. I just need some general ambient lighting for the space. But, i don't want this edge band to occur. Any suggestions for fixing it?
    the vray light is set to:
    double-sided
    invisble
    ignore light normals
    mult: 4.5
    store with irrad. map
    (i have tried it with smooth surface shadows turned on and off and still get the same results)
    for rendering, i am using irrad map + QMC. is this happening because of rendering settings that i may be using or is it because of settings with the light?
    thanks,
    sean
    Some screen shots of settings would be helpful.
    LunarStudio Architectural Renderings
    HDRSource HDR & sIBL Libraries
    Lunarlog - LunarStudio and HDRSource Blog
      here are the settings for the lights and the rendering:
      sorry about the lack of info ... fighting a deadline ...
      thanks,
      sean
        hi proces2, i think, that the grey edge could be a problem of overbrighted area caused by your vraylight+HSV exponencial high dark multiplier. try to use larger size of the light and decrease its multiplier and decrease color mapping dark multiplier also.
          just tried that out. looks like it is working. thanks!
          sean
