bug with brightness bellow 1 in matte and net rendering
  • bug with brightness bellow 1 in matte and net rendering
    Hello
    Can someone confirm if this?
    I have a plane with a box on top and a light source.
    I want the plane to be matte (-1) and the box to cast a shadow on this matte.
    If the shadow brightness is bellow 1 they disapear in all render nodes but not in the workstation that submited the job and where the manager is located.
    If brightness is 1 then all machines render the shadows.
    Can someone confirm this bug??
    Thanks
    what version of vray?
    also are there any maps in the scene? maybe an ies light?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      Hi.
      No materials.
      I just made a matte plane (receiving shadows that affect alpha) and set the brightness to something bellow 1.
      Put a box on top and a light source and send it to backburner.
      Only this machine render the shadows, the nodes don't.
      If brightness is 1 all node render the shadows.
      Can someone verify this?
      I don't know what's causing this...
        Is it something connected with the "." "," problem ?
        I will check that out too.
        nikki Candelero
        .:: FREE Your MINDs, LIVE Your IDEAS ::.
          Well, exactly as we supposed ! The problem is not in V-Ray, but that
          "." "," decimal sign. Make sure all your render nodes are set with "." [dot]
          Then the rendering is going fluently with brightness of the matte set below 1.0.
          nikki Candelero
            Hi.
            I forgot about that issue.
            Nevertheless I already changed de decimal separator but the problem persists.
            Did anyone reproduced this error?
            Thanks
              Hm, strange
              I could make it wrong and correct via BB. The difference was only the [dot].
              BTW, which BB is this ?
              nikki Candelero
                sorry...BB?
                Bounding Box, Brigitte Bardot??
                  BB = supposed to mean BackBurner.
                  Here are some other V-Ray / MAX abbs
                  __________________________________
                  DR - Distributed Rendering
                  BB - Backburner
                  IR - Irradiance
                  LC - LightCache
                  AA - Antialiasing
                  QMC - Quasi-Monte Carlo
                  CM - ColorMapping
                  List of some PhotoShop abbs
                  Mostly used when talking about layer adjustments:
                  LV - Levels
                  BC - Brightness / Contrast
                  HS - Hue / Saturation
                  CB - Color Balance
                  CV - Curves
                  SC - Selective Color
                  Feel free to add more to OUR V-Ray language
                  nikki Candelero
                    ah..
                    I'm using BB 2.3
                      I tried opening max in a node and netrender from there.
                      The node renders fine and all others don't, including this worstation that was working in the previous situation.
                      Any ideas?
                        Originally posted by RSF
                        ah..
                        I'm using BB 2.3
                        I tested it in BB 3, MAX 8, SP3
                        nikki Candelero
                          humm...I'm a bit afraid of moving to max8.
                          What's worst is that max8 can't save as max7....only 3ds
                          Anyone willing to check this issue on max7? Please?
                          Thanks
                            Ok...got it
                            Well...forgot that I have two users in the windows login
                            Changing the decimal separator in the correct one solved it.
                            Sorry...I'm not as fast as I would like hehe
                            • #15
                              Good to hear that !
                              nikki Candelero
