fresnel bug??
  • fresnel bug??
    don't know about you guys, but i am having this problem with lwf.
    i am using vray 1.47.03
    this is the setting.
    just pitch black material
    reflection : grey, value 50
    click on the fresnel
    this is what i get.
    [img][/img]
    then with the same setting, i change the material reflection to
    grey, value 30
    and this is what i get
    [img][/img][/list]
    so. i know it's a small problem, probably, someone would say,
    dont use lwf then, or don't use reflection under the value of 50...
    but then also this is not visible when you are not using wide angle camera, since my client is a wide angle camera freak, so i am getting this effect on my floor. very sharp line between the reflective and not reflective area..
    any advise my good fellas??
    thanks
    Dominique Laksmana
    Can you show an image with that floor with the sharp line.
    Thanks.
    nikki Candelero
    .:: FREE Your MINDs, LIVE Your IDEAS ::.
      Hello dominique,
      Decrease the cut-off threshold for the vraymtl and it will be fine.
        sorry vlado..
        the idea of having fresnel is to have reflection ---->to non reflection..
        if i lower the cutoff treshold, it looks like it loses it's fresnel.
        hmm... any other solutions?
        thanks
        niki, this is the image
        [img][/img]
        you will see a curve sharp line below..
        thanks
        Dominique Laksmana
          Can you also show a render with vlado's suggestion - to see the difference ; as that is how it should be set.
          nikki Candelero
            this one is with vlado's suggestion.
            [img][/img]
            the question is, can i don't have that reflection at the bottom...
            but a gradient from reflection--to non reflection
            thanks
            Dominique Laksmana
              looks fine to me...the windows are fading out towards the bottom. The amount (or falloff) of the fresnel is depending on the reflektive IOR (wich by default is locked to the refractive IOR), so to tune the look you'd have to untick the L button and adjust the IOR, no ?
              Thorsten
                if i lower down the fresnel, the cut-line is happening again...
                Dominique Laksmana
                  Try using a Blend material, which has for 1st mat - the one with reflections, and a second with pitch dark diffuse and no reflections at all.
                  Then use a Falloff map for the masking between them. Should do what you need, with no tweaking on the IORs.
                  nikki Candelero
                    thanks niki
                    that'll do!!
                    Dominique Laksmana
                      but will increase rendertimes alot i think.
                      Jonas
                      www.jonas-balzer.de
                      www.shack.de
                        if the 2nd mat has no reflections, that wouldn't be much of a pain.
                        nikki Candelero
                          couldnt you just use a falloff map in the reflection slot ?
                            same thing..
                            will also occur
                            Dominique Laksmana
                            • #15
                              Yes, that's another option, which might also do it.
                              Actually that is even simplier. Thanks.
                              nikki Candelero
