more displacement woes
  • #16
    i ve posted recently a similar problem with displacement.
    i didn t use an extruded object, instead i had a poly objet with quad faces and i was getting nasty errors when using 3d displacement...no errors with 2d, but i needed to use the continuity option, so i had to use 3d.
    then i remember this old tuturial about dispacement....and there was this "trick" on using a mesh smoth with 0 itenerations on the mesh and use 2d displacement to achieve the non detaching corners desired look. So i tried it...with few sucess i must add...it would work in the corners but as the poly was not a simple cube it woth produce some other problems....so i went on and on and after a good advise i just layed a tesselate mod on top of the mesh smooth and sticked to 2d disp and voilá! it sorted out and produced a flawless displaced brick wall!
    Nuno de Castro
    www.ene-digital.com
    nuno@ene-digital.com
    00351 917593145
