invalid color warning:using shad./light map in vray diffus
  • invalid color warning:using shad./light map in vray diffus
    Is it to be expected to have the following warning when using a falloff ( shadow/light type) in the diffuse slot of a vray material?
    warning: Texture "Map #54" returned an invalid color (RGB 1.#INF, 1.#INF, 1.#INF).
    I'm not using colour correct, or boosting the output of the map.
    Patrick Macdonald
    Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
    If you are also using GI, then I suppose it is normal. The Shadow/light mode for the Fall-off map was not really designed with GI in mind.
      I just ran into this problem too. Thought I came up with a new bug, but it looks like I am 6 months late!
      Any workaround for this?
      sigpic
      J. Scott Smith Visual Designs
      https://jscottsmith.com/
      http://www.linkedin.com/in/jscottsmith
      http://www.facebook.com/jssvisualdesigns
        dont use the shadow light falloff would be a good workaround
        Chris Jackson
        Shiftmedia
        www.shiftmedia.sydney
