1.5 matte option not working???
  • 1.5 matte option not working???
    maybe I'm just doing something wrong, but the settings we use to use for this no longer work.
    I've got a vray plane. I apply a material wrapper and put a vray material in for the base (just plain near white), then apply it to the vray plane.
    I change the material wrapper to -1.0 alpha contribution and check effect shadows and alpha.
    That use to work, but now it does nothing.
    So I thought, "lets just do it for the object." I chose vray properties on the vrayplane. Checked the matte option and applied -1 to alpha contribution. It renders invisible again.
    I have a light casting shadows and placed a plane just above the vray plane just to make sure it wasn't working. the plane does cast shadows on another plane, but not onto the vray plane in which I am trying to cast shadows.
    Can someone tell me what I am doing wrong?
    I'm having the same problem. And I did the exact same things as you - and in the same order. I'm still on 1.48.02
    Is there an issue with the vraysun not casting shadows on matte objects?
    If I use a default vraymat on everything, shadows appear as they should. When I switch to the matte objects for receiving shadows, they receive none.
    Any ideas?
    sigpic
    J. Scott Smith Visual Designs
    https://jscottsmith.com/
    http://www.linkedin.com/in/jscottsmith
    http://www.facebook.com/jssvisualdesigns
      I'm not even using vray sun.
      I am, however, using the new IBL, image based lighting, and one photometric light. Although, i would think the photometric light should cast the shadow without a problem. It did in my tests...just not on the matte object.
      Anyone else had this issue? I haven't had it until 1.5
        This seems to work fine here as far as I could test, so if you have a scene for this, you can try sending it to vlado@chaosgroup.com
        Do you use the physical camera, by the way? Is the "affect background" option for color mapping on or off?
          did you find any issue about this?
          I reset 3dsmax, drawing a box whit a cilinder on top, one light, doing the box matte object via vray object parameters, -1 alpha... and doesn't work. It doesn't matter if I check or uncheck affect background.
          That was using 3ds9 64bit, Vray 90 RC4a 64bit.
          If I do the same in the old 1.47 version, it works as always.
          Maybe to produce the same effect as before I should change some other thing.
          Any help would be appreciated.
          Manuel
            For any issues with non-official V-Ray builds, please email me directly to vlado@chaosgroup.com
