Render to fields problem
  • Render to fields problem
    Hi there,
    We're in the middle of a huge project and we need to render all projects with fields for tv. The problem is that when we turn render to fields option on, some frames get the top part black.
    Since we're starting the rendering process, if you have any tip about this, please share
    Thanks in advance,
    Rui Romano
    www.ingreme.com
    I've run into the same, if not a similar issue. Turning off show calc. phase in LC fixed the problem for me. Hope that helps
    Austin Watts
    Render Media
    Blurring more than 20,000 cars since May, 2001.
      U just saved my life, hehehehe!
      Super thanks Austin
      cheerz
        I would like to know if this problem is solved in current Vray RC2 version. Can I have Show Calc. Phase turned on when rendering to fields ? Thanks in advance.
        Artur Leao | Co-Founder / Project Manager
        You can do it! VFX
        Porto/Lisbon - Portugal
        http://www.ycdivfx.com
          This is corrected, yes. The "Show calc. phase" option will be automatically turned off if you render to fields.
            Thanks, i had the same problem. hope this helps.
