Hello all,
I’m experiencing a few problems with 1.5 and older max files. We never experimented with any of the Beta builds in the 1.4 range. We went straight from 1.09r to 1.5.
The first problem I encountered was very slow GI pre-passes (see example). You can see a huge difference in times. This was an animation test I was working on and I have had this problem with other max scenes.
The other issue was a GI problem on a file (see other example). It gives the appearance that the GI is not working at all. I did the following test with same results.
1. Reset Vray
2. Merged the scene into a fresh max session and started up Vray for the first time.
3. Changed the lighting from Direct Max light with Vray shadows to Vray sun.
At this time, I have not started a new file using 1.5, so I do not know if I will experience similar problems.
I’m hoping I can get this resolved because I need 1.5 to handle the larger scene…….1.09 crashes or gives me an error message constantly and I have deadlines coming up quickly.
Any input would be greatly appreciated.
Thanks,
Scott.
www.drealm.net/Projects/Vray/pre-pass.jpg
www.drealm.net/Projects/Vray/GI.jpg
1. Reset Vray
Thanks,
Scott.
