dr rendering problem using 1.47 vray and max 8 with backburn
  • dr rendering problem using 1.47 vray and max 8 with backburn
    It keeps failing. It works in default scanline when I choose split scan lines in the network job assignment in backburner. I selct DR in vray systems and then I have tried it with both cheking off split frame in the backburner and without it checked on and both times in fails.
    res3d
    You cannot use DR in jobs being rendered through backburner.
      what do you use if not backburner? I do have spawner running in the background.
      res3d
        Re: dr rendering problem using 1.47 vray and max 8 with back
        Just regular rendering.
          ok, that worked. I was turning on nework rendering in MAX, which was taking me to backburner.
          res3d
