Fine Detail
  • Fine Detail
    Howdy all... what variable would I tweak to increase fine detail? I have a strip mall - exterior scene that has dryvit details that are not being picked up. The detail is the same color as the body. The sun is place in real time so I can't mess with that. Any help would be greatly appreciated.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Save
    A related question possibly..... when I burn my gamma by using the sRGB and save it as a OpenEXR it looks great, but I have a white box around everything that touches the background... my trees in front of my VRaySky... Any clue how to get around this?
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      well, one of the issues might be premultiplication - you need a compositing app that can deal with its alpha correctly. As for the fine detail, better aa such as using the adaptive subdivision method works better but if you're using glossy or blurry effects like dof / motion blur / soft reflections it will slow things down a lot. Try using a sharper antialiaser such as mitchell or catmull too.
        Fine Detail
        I'll try catmull, thanks... I use PhotoShop for post. Would you recommend something else? If I save as a TIFF and put a curve on it PhotoShop I am fine, but it is an extra step.
        Thanks for the reply
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Strangely enough photoshop has the worst support for alphas out of any image editing program I use - you'll probably have to use the defringe and remove layer matting options to get rid of the halo or as you say do the gamma curve in photoshop.
            alpha
            ok, thanks for your help.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              EXR
              I have found out you can un-check the premultipli box when you open the EXR in PhotoShop.... that solved the white box issue. My other question is how do I get detail to show more. The arrow shows detail in the dryvit that just isn't showing... see the arrow on the left? That detail goes around the front of the building. Other than changing the color what can I do?
              http://www.whitebirchstudios.com/share/northwood.jpg
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                You'd probably want to do an ambient occlusion pass and comp it over that texture, or else if you're on 1.5 just check the detail enhancement checkbox in the irradiance map.
                  Detail
                  I'll try that check box, thanks....
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
