"auto added" vraysky on vraysun creation has no na
  • "auto added" vraysky on vraysun creation has no na
    When creating a vraysun and it asks you if you would like to automatically add a vraysky environment map, this map has no actual name.
    So when you try to instance it from the max environment slot into the vray environment slots, a window pops up asking you to give it a name.
    Can this be fixed so it has a name and therefore doesnt require this "naming" popup
    I don't have that problem. it works for me...
    best regards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
      Thats strange cause I have tried it in both max8 and 9 and the vraysky that is automatically created and put into the max environment slot has no name. FOr instance drag it into the ME and you can see
        i never have seen this. you mean after you place a vraysun in the scene you get a popup asking if you want to create a vraysky?? nothing like that happens when i create a vraysun. i have to make the sky through the mat editor and drag/instance it over to the environment slots. it would be if it did all this automatically.
        am i missing something?
        www.boxxtech.com
          In RC3, when you create a vraysun, it will put a pop-up asking you whether you want to automatically put a vraysky in the environment slot as well.
            Vlado, are you aware of the no name problem?
            Would it be possible to add a tick box or 2 so the user could choose to add it into the vray skylight and reflection override if he or she wanted to?
              actually i got the same thing. no name when you drag it into the ME. it states its a vraysun map but it doesnt name it
