Reflection of a Window in a mirror
  • Reflection of a Window in a mirror
    Hi all
    I have search for a while, but not found such a topic...
    I am rendering a simple scene of a bad as you see below.
    I have Vray light on my window. The question is why through the window i can see the sky and in the mirror i have this white reflection?
    Many thanx in advance!
    Express Your Imagination - let it MAX!!!
    www.3dkad.de
    Do you have "affect background" ticked in your vray colour mapping rollout?
    Patrick Macdonald
    Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
      Yes i have it.
      www.3dkad.de
        what is the max depth set to on the mirror and the glass?
        Chris Jackson
        Shiftmedia
        www.shiftmedia.sydney
          You need to enable reflective gi caustics, which I believe are off by default. Not the photon caustics - the ones in the Indirect Illumination (GI) rollout.
          Surreal Structures
          http://surrealstructures.com/blog
            Try unchecking 'affect specular' in the light properties.
              Thanx all for your replies...
              I have tried a couple of things but the true is that by the Vray lights there is a Affect specular option. When the option is off everthing seems to be all right.
              I wish u good luck!
              I will post the result in the Image uploads section.
              C u around!
              www.3dkad.de
                Hei cubiclegangster...
                I have just writing my post and when i posted it i have seen yours - that is the solution
                Thanx anyway :P
                www.3dkad.de
