Spawner Problem and Solution
  • Spawner Problem and Solution
    Although this may be obvious to others, I have just learned that if you have 2 different spawners open (for example VRay Spawner 60 and VRay Spawner 90) only 60 will work. 90 appears to be downward compatible as it works with at least one earlier version of Vray.
    Hope this saves someone the wasted hour I just spent figuring this out.
    --ds
    I would assume that both versions of the spawner use the same port?
    If so, maybe this could be changed?
    -- DJ
