twilight zone - render problem
  • twilight zone - render problem
    I know that it´s actually senseless, but nevertheless I try to describe my problem and who knows...maybe someone has a clue.
    We have an interior animation. Two cams. One is moving from left to right, one is going from the back wall forward. cam one renders okay, cam two creates a horrible flickering in the GI. And there is absolute no logic I can follow :-/ we tried everything. changing the cam, use the okay cam and changed the path, merged the scene, tested with max 8 and 1.48 and max 9 and 1.5, collapsed all etc etc...i can´t imagine one single attempt that we didn´t try. I could understand it if both cam produce a flickering GI, then the issue must be in the scene. But just one ? and even if we create a new cam or render the movement with the other cam. somehow i feel a bit like in the twilight zone....but who knows, maybe someone has an idea..
    thanks in advanced
    sounds wierd, how far from the origin is your scene?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      all in centre 0,0 ...i checked it before...really weird..even without reflection etc. same result
        send me part of your file if you can
        Chris Jackson
        Shiftmedia
          ..and it´s obviously the case that i have to render each frame with a new IR map (moving object) ...with a precalculated map it works...but that don´t help me...normaly I don´t have problems to render the GI for each frame. so far it worked
            maybe the lightcache ? can it be possible that on each machine the lightcache solution (4 passes) is too different from each other that it has such a big effect ?
              post up your settings or some images
              Chris Jackson
              Shiftmedia
