Particle Flow error
  • Particle Flow error
    I have imported a PFlow into a new scene, and when I try to render I get the following errors.
    error:UNHANDLED EXCEPTION: Calling EvalWorldState() for node 'PF Source 01->Event 01' at time 7488 Last marker is at .\src\staticmeshinfo.cpp, line 467: StaticMeshInfo::buildNormals()
    error NULL mesh in StaticMeshInfo::compileGeometry()
    Why is this happenening? and how do I fix the error without rebuilding the Pflow from scratch?
    Patrick Macdonald
    Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
    Which V-Ray version is that?
      It was RC3, but the error was my fault. I had a PFlow system without its emitter.
      I guess vray was trying to create the mesh for the pFlow but couldn't as there wasn't any particles created. ?
      Patrick Macdonald
        Yep, although crashing is probably not the best way to complain about it; I'll try to correct this.
        Best regars,
