Normal map in a VRay material ?
  • Normal map in a VRay material ?
    Is there a way using normal map with VRay material ?
    I put a "Normal bump" in the bump slot of a VRay mat with absolutly no effect (...and I works well with a standard mat).
    VRay 1.43.09 and Max 8sp3
    Regards, Fabrice.
    www.protozoaire.com
    Khem. Can't help here, I'm using 1.5 RCx
    I just can't seem to trust myself
    So what chance does that leave, for anyone else?
    CG Artist
      You should get a newer version of V-Ray.
        I'd be very happy to have 1.5, but I waiting for my 2 dongles for about 3 weeks, with absolutly no news from Chaos...
        btw I think normal maps are in 1.5 ?...
        Thanks.
        Fabrice
        PROTOZOAIRE
        Regards, Fabrice.
        www.protozoaire.com
          You can install V-Ray 1.5 RC3 without a dongle, using your existing license.
          As far as I could test here, normal maps work fine with VRayMtl.
            Ok I didn't know there was a dongle-free version of 1.5.
            I won't update now because 3 different works are actually on production.
            Anyway...can normal map work with my actuals 1.47.09 ?
            And how, I couldn't make it...
            Regards, Fabrice.
            www.protozoaire.com
              Eric Boer
              Dev
                in other works stick with a standard map until you update.
                If it doesnt work with vraymtl it doesnt work.
                  With 1.47 use a max material to get the proper effect
                  Two heads are better than one ...
                  ....but some head is better than none.....
