replacing vray proxy during render
  • replacing vray proxy during render
    Hello,
    if this is for the offtopic section- please move it there.
    I read a lot about the possibilities and not possibilities of faking animated vray proxies.
    Vlado says in this post, that one should replace the mesh file for every frame.
    I did this and it works fine in the viewport, but when rendering a sequence the object isn't replaced by its proxies ... I need to render each frame one by one ...
    Before I spend to much time on this topic - I dare to ask if someone has a solution for this?
    Is it technically possible? Or is it a fact that starting the render freezes the object geometry ?
    Changing ie a text over time works - because it is a property?
    Changing the proxyfile doesn't work because it is wasnt meant to do this?
    I highly appreciate any fog clearing answers.
    Georg
    [/code]
    In Polygongewittern - Industrial Parametrisation of the World
    http://www.preset.de/
    http://www.count-as-one.net/
    Unfortunately the proxy seems to only use the file from the first frame, rather than read the file name for each frame; I'll try to correct this for future builds.
    A somewhat tedious workaround for now is to create many proxies with the different files, but change their visibility over time.
      A script can handle this.
      Thank you for your answer!
      Georg
