RPC + Physcal Cam + Distibuted Rendering
  • RPC + Physcal Cam + Distibuted Rendering
    Hi all,
    i try to switch to vray physical cam but i have a prob with distributed rendering. I make a lot of projects in DR and Standard cam without probs but with a physical Cam, all my renders nodes not render rpc. Any solutions ?? Thanks.
    http://www.a-3d.fr
    I think this is a known problem. VrayPhysicalCamera does not render RPC's.
    I'm not shedding any tears though...
    "Why can't I build a dirigible with my mind?"
      No RPC works with physical cam, like i said in another post but not in Distributed rendering + Physical Cam.
      Method to render rpc with a physical Cam:
      1. By default when you create a rpc in max, all are excluded from light. So in Vray Sun clear all rpc in exclude list.
      2. If your rpc are too dark, try to set Illumination in mass edit dialog to inverse. EX: For a tree with 75% illumination by default, set to 100-75 = 25%. It's works fine for me. if you want more dark set to 50%, etc...
      http://www.a-3d.fr
        I noticed the same with RPC's and DR, nodes don't render them
        Is there a solution or workaround already to make the rendernodes properly render the rpc's?
        3DV - Ruud van Reenen
        www.3dv.nl
          My bad, a typo in the path for RPC's on the rendernode...
          Tested now, and rendering rpc's with DR works perfectly.
          Greetz, Ruud
          www.3dv.nl
