Saved lc renders black
  • Saved lc renders black
    Hello
    I render basic scene using lc in primary and secondary gi. It looks ok.
    Then I save vrlmap and turn lc mode to: From file.
    I render scene again and it shows only black. Why?
    -LarsSon
    Lasse Kilpia
    VFX Artist
    Post Control Helsinki
    Hi
    are you sure you are rendering from the correct LC file? are you using DR?
    Natty
    http://www.rendertime.co.uk
      Yes it's the correct file and no DR.
      I'm using 64bit Max and V-Ray. ...if it makes any difference.
      Lasse Kilpia
      VFX Artist
        Which V-Ray version are you using?
          Is "dont render final image" still checked ?
          http://mikebracken.cgsociety.org/gallery/
            I'm using 1.5 r4
            Lasse Kilpia
            VFX Artist
              Originally posted by LarsSonparsson
              I'm using 1.5 r4
              In that case, please email me to vlado@chaosgroup.com
                Ive had this problem quite a few times using the LC on a really high res image.
                Just use qmc now instead... a global solution would be nice though.
                  Well, i'm trying to render interior animation, so qmc is not
                  the best solution this time. I even tried scene with box and teapot.
                  Render resolution was 640x480. No go. I don't think that the reason is related
                  to scene complexity or resolution.
                  Anyway, i'll wait what Vlado knows about this.
                  -LarsSon
                  Lasse Kilpia
                  VFX Artist
                    We just tested same thing with V-Ray 1.5 r3 32bit version and
                    everything worked just fine. So, the problem is only in 64 bit version.
                    (maybe in r4d version).
                    So, Vlado if you can help us somehow, that could be so great.
                    (I did send email to you earlier)
                    Deadline is so near... again...
                    -LarsSon
                    Lasse Kilpia
                    VFX Artist
                      ...err... anyone?
                      I'm still having this same problem and no one is helping me.
                      Vlado, I did send you two mails about this "bug". Could you please respond with something. I just want to know if there is some fix coming or
                      some workaround we could try.
                      LarsSon
                      Lasse Kilpia
                      VFX Artist
                        Sorry this isn't help but I also have same problem sometimes with 3s bit max8 sp3....
