Flickering VrayLight reflections
  • Flickering VrayLight reflections
    Hi everyone! I was wondering if you can help me.
    I have a few Vray lights reflected on glass. When I render the sequence, the light reflections appear to be flickering on the glass. Any ideas? I have tried to increase the reflection subdivisions on the glass material nothing happened.
    Please note that the glass has refl. glossiness 1.0 and subdivisions 20 interpolation is off..... any ideas??
    Thanks
    Vray ROCKS!!!
    try setting the reflection cutoff to 0 in your material, see if that helps
    regards, michael
    This signature is only a temporary solution
      Can you post some images of the flickering region?
        Here is one frame from the animation. You can see the reflection of the square lights one the glass left.
        [/url]
        Vray ROCKS!!!
          Ok then; what are your antialiasing settings?
            Here you are Vlado,
            Image sampler is Adaptive subdivision
            Antialiasing filter is on and Area with size 1.5
            Adaptive subdivision image sampler settings are
            Min -1
            max 2
            Clr thres 0.1 and Randomize samples on
            Vray ROCKS!!!
              So you can try either 0/2 for adaptive subdivision sampler, or the Adaptive QMC sampler.
