DR Slave Issue
  • DR Slave Issue
    Sending comp> Max9 x32, Slave> Max9 x64
    I have setup a startup script to run all the cores on the slave. The scene loads on the slave but the Vray log states "Server xx.xxx.xxx.xx: Starting Frame 4" over and over. No buckets render. BTW I am not rendering frame 4. Thanks.
    There is a problem in RC3 that will prevent DR to work properly with mixed 32- and 64-bit 3dsmax. This is corrected for RC4.
