Vray Render elements, Mtl_select
  • Vray Render elements, Mtl_select
    It seems that vray_mtlselect render pass isnt working right? I put vray material with dirt in diffuse slot into vray_mtlselect parameters material slot and when I render I get black render with alpha in the alhpa channell? why I cant get dirt in there?
    Another problem is that I cant drag any material from meditor to vraymtlselect material slot and neither viceverse. I think this is a bug?
    Best Regards,
    Erko Raaman
    www.erkoraaman.com
    You need to have the material applied to something in your scene. VRayMtlSelect only extracts this material from the image and puts it in its own layer.
    Render elements in V-Ray can only extract information that is computed during the normal course of rendering calculations; they cannot show information that is not in the rendering.
      I see. now its works fine. drag drop bug is not the big problem sience u can select the materials from meditor dialog
      anyways. I was looking for extra pass for ambient which I made with dirtmap. but if I need to add this dirtmap to all scene objects then I can use mtl override and just output the ambient pass.
      What is the use of mtlselect? what is the difference of mtl override and mtlselect then?
      Best Regards,
      Erko Raaman
      www.erkoraaman.com
        I think you misunderstood the purpose of Mtl_Select. It is not meant as an alternate Material Element, but it is meant to isolate a specific material in a seperate renderelement. That way you can render out an extra element that contains only the objects that have the materials applied.
        Regards,
        Thorsten
          yea. I was just looking something handy now this is very clear.
          thanks! :P
          Best Regards,
          Erko Raaman
          www.erkoraaman.com
