Weird Vray Cam problem...
  • Weird Vray Cam problem...
    Has anyone seen anything like this?
    The scene is acting weird, it renders a crop completly at random, the only thing that helps is merging everything into a new scene, but i've done that about a dozen times.
    Dusan Bosnjak
    http://www.dusanbosnjak.com/
    Show your vray cam settings. As render can't be 100% matched to viewport.
    CG Artist
      When i merge the scene, and use the same camera with the same settings, it matches the viewport. Dunno if it's a 100% but its very very close.
      On the other view, this problem was far more exaggurated, when the camera cropped to an area that was about 1% of the whole image.
      Dusan Bosnjak
        make sure you don't have a zoom set.
          zoom set?
          Dusan Bosnjak
            you've probably got unchecked the 'get resolution from MAX' in the vray fsb which can be in effect even if even if your not using the vray buffer (and even if its greyed out)
            WerT
            www.dvstudios.com.au
